smaller companie (group of five designers) that do not have a special reviewer that can do review/approval.
Is there any way I can setup a criteria in Vault so a designer is not abel to approve hes own files?
Need more information. Version and level of Vault (for example Vault Pro 2013)
Are you using ECO's? If so, yes..... you can decide through user or group security and the ECO routing who has the authority to approve.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I think you might be interested in this thread:
It describes some code you can run to so that the user who promotes a file is not the the one that approves it. This feature is not available out of the box. Add it to the Ideastation if you think it should be added to Vault.
I have not run the code, so you might try it in your test vault before you put it into production.
Steve Walton
