You will need to manually publish each IDW file before adding it into the
Vault.
Once you do this, each time you check it out and check it back in, the
multiple dwf's will be published automatically.
But this will not happen, unless you do the manual publish first.
Hope this helps.
John Laidler
INCAT
www.incat.com/autodesk
wrote in message news:5391875@discussion.autodesk.com...
(IV 11 dwf ext, sp2 & Vault 5.)
After checking idw's back into my Vault, I was planning to send the
automaticly created dwfs to purchasing to obtain quotations. ( or give them
access to the DWF folder).
But, after reviewing a few DWF's I find the only the first Sheet of a Multi
Sheet DWF is published.
Do I have the 'Create DWF Attachemet' set up correctly, or is this a known
bug?
Conor.
