Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
not possible to checkout many data at once
8 REPLIES 8
Message 1 of 9
528 Views, 8 Replies
Hi all, if I try to checkout a folder with many data and dependencies, the windows "freezes". Normaly the OK-button should angray after the progress-bar has disappeared, it stays disabled. It's not a new problem, I have it for a long time now. Is there already a solution? (I'm using Vault 2011 SP2)
8 REPLIES 8
Message 2 of 9
any news? Does no one have an idea? Should I contact the support by mail?
Message 3 of 9
Hi all,
I still have the problem, that I cannot check-out larger forlders! Is there nobody else with this problem?
I can reproduces the on every client-pc. I have installed all hotfixes
Message 4 of 9
luttena
Hello. I'm sorry to hear you're having this issue. Can you give us an idea of approximately how many files you're attempting to download? This will help give us a good idea of what you're working with.
Adam
Adam Luttenbacher
Sr User Experience Designer
Message 5 of 9
the problems start at about 1000 files. On the other hand I can download the complete vault without any problems.
By the way: I have the german version and with "checkout" I mean "Abrufen / Auschecken".
Message 6 of 9
luttena
Interesting. Just to clarify, you are seeing this on more than one machine?
If you were seeing it on one machine, I would guess that the problem is that the dialog has populated on a second screen. I see that issue come up often. The dialog is off the screen when only one screen is viewable.
Do you think that's an option here? Are you using multiple monitors?
Adam
Adam Luttenbacher
Message 7 of 9
in reply to: luttena
The problem is 100% reproducible and happens on all machines (also machines with 4 screens).
I can even see the checkout-dialog and the software is not freezed, but the ok-button is disabled so I cannot continue.
Message 8 of 9
cbenner
Message 9 of 9
in reply to: cbenner
it's definitely not hardware-related!
I'm actually sitting on a i7 860 with 8GB RAM, 1Gbit LAN.
The Vault-server is installed on a i7 950 with 24GB RAM, 10Gbit LAN.
