Hi all,
I still have the problem, that I cannot check-out larger forlders! Is there nobody else with this problem?
I can reproduces the on every client-pc. I have installed all hotfixes
Hello. I'm sorry to hear you're having this issue. Can you give us an idea of approximately how many files you're attempting to download? This will help give us a good idea of what you're working with.
Adam
the problems start at about 1000 files. On the other hand I can download the complete vault without any problems.
By the way: I have the german version and with "checkout" I mean "Abrufen / Auschecken".
Interesting. Just to clarify, you are seeing this on more than one machine?
If you were seeing it on one machine, I would guess that the problem is that the dialog has populated on a second screen. I see that issue come up often. The dialog is off the screen when only one screen is viewable.
Do you think that's an option here? Are you using multiple monitors?
Adam
The problem is 100% reproducible and happens on all machines (also machines with 4 screens).
I can even see the checkout-dialog and the software is not freezed, but the ok-button is disabled so I cannot continue.
I just tested this on a folder with over 1,600 files and it worked ok. What are your computer/network specs? Perhaps the problem is hardware related?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
it's definitely not hardware-related!
I'm actually sitting on a i7 860 with 8GB RAM, 1Gbit LAN.
The Vault-server is installed on a i7 950 with 24GB RAM, 10Gbit LAN.
