Thank you for your post Kirk,
You are greeted with that dialog because Inventor is populating it, not
Vault. The Vault add-in is simply adding your file status information as a
warning.
To resolve this problem, navigate to Tools>Application Options. In the
"Save" tab, you will see an option "Do not list referenced files that
default to "No" in the Save dialog." Checking this box should eliminate
these extra files from you save dialog.
Adam Luttenbacher
wrote in message news:5321397@discussion.autodesk.com...
When I try to save an assembly, I am greeted with a Save dialog. In it,
several of the files have "No(file is not checked out of Vault)".
Is Vault wanting to save this file? if not, then why is it even showing me
this.
Does the file need to be updated in some why?
If I change this to "Yes(file is not checked out of Vault)", then I get the
Edited-out-of-turn. Which, to me, I do not like to see.
Can someone please explain.
Vault5-sp1
