Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
no copy content center files to copy design vault 2012
3 REPLIES 3
Miquel
598 Views, 3 Replies
For 3 versions in Vault, on copies design, we manually uncheck all library files. There is an option to do so automatically, but this option is disabled. Is there any way to activate this option? attach video.
3 REPLIES 3
yuhui.zhang
in reply to: Miquel
Thank you for the posting. In Vault 2012, there is a new command 'Reuse Library Files' introduced to batch set Library files to Reuse from Copy. You can right click the assmebly file, apply command Reuse Library Files from context menu, then all Library Files under this assembly will be set Reuse. Please refer to attached image & video, wiki page notes this as well.
Fay Zhang
Software QA Engineer
Data Management
Be sure to check out the Vault Help Wiki!
Miquel
in reply to: yuhui.zhang
I tried and works, thank you!!!
kprom
in reply to: Miquel
Nice bandaid, why did the default behavior change?  This was really annoying when an error popped up, preventing unchecking.  Thankfully a hotfix fixed this.
Thanks for the tip.
