For 3 versions in Vault, on copies design, we manually uncheck all library files. There is an option to do so automatically, but this option is disabled. Is there any way to activate this option? attach video.
Solved by yuhui.zhang. Go to Solution.
Thank you for the posting. In Vault 2012, there is a new command 'Reuse Library Files' introduced to batch set Library files to Reuse from Copy. You can right click the assmebly file, apply command Reuse Library Files from context menu, then all Library Files under this assembly will be set Reuse. Please refer to attached image & video, wiki page notes this as well.
Hope it helps.
Nice bandaid, why did the default behavior change? This was really annoying when an error popped up, preventing unchecking. Thankfully a hotfix fixed this.
Thanks for the tip.
