Well said Pete...
Never, ever, link 100+ parts to the same Excel file. That's a beginners
mistake. Link the Excel file to one part, and derive that part into the
other parts and assemblies. You will only have one OLE link to manage.
Embedding the Excel file is an option, but I would rather see DA handeling
OLE links.
Cheers!
T. Ham
Mechanical Engineer
CDS Engineering BV
Dual Pentium XEON 2.2 Ghz
2 GB SDRAM
NVIDIA QUADRO4 700 XGL (Driver = 77.18)
18 GB SEAGATE SCSI Hard Disc
3Com Gigabit NIC
Windows 2000 Professional SP4
Autodesk Inventor Series 9 SP4
Autodesk Inventor Series 10 SP3a
wrote in message news:5078614@discussion.autodesk.com...
I am assuming you have many files referencing parameters from a common
spreadsheet. This is what I have done.
I create the spreadsheet to drive all my parameters, "Skeleton.xls" I then
embed this spreadsheet into a blank ipt file, "Seleton.ipt" I set all my
embeded parameters for export (check the export box for each). I insert
this ipt in all my parts that would have referenced my spreadsheet as a
"Derived" part with a plus by "Exported" parameters.
I can still update the spreadsheet to update all the parts by editing the
embeded spreadsheet. The only draw back is if you add or insert the
parameters they don't show up in order.
Pete
