All,
We (the Vault team) would like to make the group aware of a new hotfix that we just released to the support page. You can download the hotfix here for 2012, 2011 and 2010.
2012 - http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=18480860&siteID=123112&linkID=9261341
2011 - http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=18480822&siteID=123112&linkID=9261341
2010 - http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=18480586&siteID=123112&linkID=9261341
This latest hotfix addresses a number of potential issues around property synchronization, copy design, permissions as well as some cumulative updates depending upon the release.
One important fix addresses a recently discovered issue with the Purge command that has affected a limited group of customers. In some cases, the Purge command has left some unresolved file references, resulting in an unresolved reference dialog or incomplete where-used results.
While we work to resolve this issue, we recommend that our customers discontinue use of the Purge command, and have included technology within the latest hotfix that restricts and reduces the impact of the Purge command.
Please continue to monitor this newsgroup thread to learn more about additional software updates as they become available.
Kindest regards,
Jeremy Lambert
Jeremy Lambert
Sr. Product Line Manager
Data Management Solutions
6. Run ADMS b2bmigrate operation in command line mode:
a. Example: Connectivity.ADMSConsole.Exe -Ob2bmigrate -VUadministrator -VPadmin_password -DBUsql_user -DBPsql_password
b. NOTE: Replace 'admin_password' with the appropriate administrator password for the -VP switch.
c. The last two command line parameters are required only if the 'sa' password is not the default password.
A few questions.
1. Is this step necessary? It seems to work without migrating.
2. My administrator password is blank, what should I do?
Yes step 6 is necessary to run.
You can use the -VP command without putting in a password.
Applied hotfixes will not be shown in the About dialog. You can examine Programs and Features, select the 'View installed updates' link and the hotfix number will appear adjacent to your qualifying installed product.
You may also check the version of the updated file(s) as specified in the accompanying readme.
However, this will not ensure that the hotfix has been installed completely. You should always examine the readme to see if there are further instructions. In this case, a Vault migration is required to consume the change.
Does this hotfix disable the purge altogether?
I've tried purging old versions of a file that are not, and have not ever, been used in another assembly. Running the purge on the specific from the client and also doing a global purge from the server console seem to have no effect. Even IDW files seem to be locked from purging.
Exactly the same problem. Purging cannot be done on the Vault client UI. Before the patch you had the ignore option box which allowed you to purge old versions regardless. Ticking this option does nothing now
Is there going to be a fix even though 2013 is out now?
Hi Gents,
Please continue to watch this space. At this stage development are actively working towards a resolution around the purge functionality and the current restriction we have placed on purge in the 2012 and 2013 products.
There will be updates released for both 2012 and 2013 in due course. Please feel free to reach out to me directly if you have further concerns.
Cheers,
we have an issue with hotfix : Hotfix - DWF Creation (DL18963992)
It doesn't install on Vault 2012 Update 1 ( basic ) but in readme all versions of Vault are listed.
Best regards,
Alex
Hi Alex,
That is a typo in the readme. The update applies to versions containing document management functionality (i.e. Vault Workgroup, Vault Collaboration and Vault Professional).
This update does not apply to basic Vault. I'll correct the typo.
Since there a lots of different hotfixes, patches will Autodesk recompile a fresh install of the Vault 2012?
Can someone clarify something for me on these?
Does the hotfix for 2012 actually fix the issue with Purge or does it simply disable the Purge command until a real fix is created?
Hey JIm,
Please see details in the thread - I will contact you directly to discuss your specific filestore issues and perhaps look at migrating to ADMS 2013 to address this.
@CelticDesignServices wrote:Can someone clarify something for me on these?
I'd also like the answer to this question.
Thanks.
Bob
Purging is completely disabled for the moment.
I turned in a support request to clarify this question. At first they didn't want to answer, just referring me back to this thread. But they finally responded: "The hotfix was to temporarily disable the purge command..."
I was trying to get all files in the vault in a completely updated state and purged before upgrading to 2013. Not sure if I should continue anyway or wait.
rant
Disabled purging won't cause any kind of immediate problems but the filestore will grow uncontrollable before too long. In the meantime at least we know what’s going on and we won’t be beating our heads against the wall. As with all bugs in the software: It’s a huge and complicated set of programs. It’s never going to be perfect. However it would be very helpful if Autodesk could just give us a little feedback. Like, “yes we recognize there is a problem” and “we are/aren’t working on it”.
It would have saved me hours trying to get a simple purge to work if they had just said in plain english, "this hotfix disables purging". How hard is that!
/rant
Hi Bob,
Please see the initial post on this thread - apologies if this was not clear:
"While we work to resolve this issue, we recommend that our customers discontinue use of the Purge command, and have included technology within the latest hotfix that restricts and reduces the impact of the Purge command."
As suggested please continue to montotor the thread for further updates on the purge command and any additional fixes.
I hope this helps
Thanks for the info Allan. We're coming up to the 3-month mark since the original post. Any guess as to when the purge issue is going to be fixed?
John Huber
Engineering Escalation Team
I am using Vault Basic and the "Patch" has disabled purging.
BL4849 (and All),
The "Purge" hotfixes apply to all Vault products including Vault Basic (per the links in the original post).
In response to Alex' query about "Hotfix - DWF Creation (DL18963992)", I posted "That is a typo in the readme. The update applies to versions containing document management functionality (i.e. Vault Workgroup, Vault Collaboration and Vault Professional)." This hotfix does not apply to Vault Basic.
With respect to "recompile a fresh install"...that would be done in the context of a service pack. We periodically schedule these depending upon technical need.
All,
We just posted hotfixes for the 2012 and 2013 Vault releases that provide a fix for Job Processor.
A similar hotfix for 2011 is in progress. While these do not address all of the Job Processor issues, it should help to alleviate some of the errors encountered.
