Hello There.
From page 23 in the file C:\Program
Files\Autodesk\Data Management Server\Help\ADMS_2009_ImplementationGuide.pdf you
will find a description, which I repeat in bullit points below.
The steps you need to take are:
Uninstall the current ADMS (and Client) from the
Server. This will also uninstall the AWS (Autodesk Web Server for local access
only - info for anybody reading this message).
On Server - Go to Control Panel, Click on Add or
Remove Programs, and select Add/Remove Windows Programs, and check the option
for Internet Information Server. Click Next and OK. You might need to dust off
and use the Installation CD for WIndows Server at this point.This installs IIS
on the server, to allow the Clients to communicate with the Server through
IIS.
On Server - Install ADMS
From Client - check that you can login to
<Servername>.
At this point your installation should be
done.
I hope this helps getting you started.
Best regards
Uffe Bak
Customer Success Engineer
Data
Management, Autodesk
Manufacturing
tutorial?
