I don't find this information into the knowledge base.
Which are the needed UDP we must conserve in a Vault Pro configuration?
By default, there are many UDP and I want to know if I can delete (or disable) all of those properties.
I have some doubt regarding UDP like "Equivalence Value", "Type", etc.
Please see in attach all default UDP.
Thanks in advance.
It is my understanding that any Property that is not a system property, can be deleted unless it is being used by the Vault somewhere. If it assigned to a file, or a gategory of... anything, Vault will not allow you to delete it.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
