Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Multiple Licenses Issued
4 REPLIES 4
251 Views, 4 Replies
User logs into Vault once & the license manager issues 2 Vault licenses. (Vault Collaboration 2013)
Any one heard of this before? Is there a workaround/fix?
4 REPLIES 4
olearya
HI Marshall,
Can you share a little more detail on where you are seeing this?  The actual ADMS log does track every integration that the user logs in via (Job Processor, CAD integration, Vault Explorer etc), but will only check out one license for that user as long as he is accessing it from one machine.  SO you will see multiple license acquired calls but only 1 license actually used.
I hope this helps.
Allan
Product Manager
Autodesk, Inc.
tmoney2007
You can look at the license identifier and see if they are using the same license.
In general it is 1 license per Username/Computer combination.
steveh3
in reply to: tmoney2007
FYI...We had an issue running Inventor 2013 with a 2014 Vault Client where it would consume two licenses. Since we switched to 2014 Inventor with 2014 Vault Client, the issue has gone away.
Inventor---Vault Professional
minkd
in reply to: steveh3
FYI - the problem steveh is refering to was fixed in 2014 SP2 (non-subscription), and 2014 SR1/SP1 (subscription). -Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
