Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
multiple library folder?
1 REPLY 1
wesbird
380 Views, 1 Reply
  I just start work on Vault. We have multiple client A, B, C, D, etc. I create fold for them. each client have their own titleblock xref. I like to put them in library folder. I found I can only create library folder at root folder. so I have to creat a folder structure like this:
--ClientA
--ClientB
--ClientC
--ClientD
--Xref (library)
  --ClientA (library)
  --ClientB (library)
  --ClientC (library)
  --ClientD (library)
  is it possible to create a folder structure like:
--ClientA
  ---Xref (library)
-ClientB
  ---Xref (library)
--ClientC
  ---Xref (library)
--ClientD
  ---Xref (library)
  Question 2: if it's not possible, what should I do to migrate all our dwg with Xref? is a option in Autoloader can do this?
Thank you and have a nice weekend
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
Tags (1)
1 REPLY 1
olearya
in reply to: wesbird
Hi There,
I am not sure if the support team have already answered this for you, but it is not possible to mix normal and library folders.
You can of course create a normal folder and simply label this a library file for the sake of consolidating data - there will be some differences in file behavior but if you have Vault Worgroup or Professional there are other security controls you can place on files that are considered library.
You can also restructure your data, before or after loading into Vault as we use relative paths - I would test this approach to see what works for you.
Allan
Product Manager
Autodesk, Inc.
