Hi OwenW,
These are the software applications that compatible with Vault 2009:
Autodesk Inventor 11.x / Autodesk Inventor 2008 / Autodesk Inventor 2009
Autodesk Inventor Professional 11.x / Autodesk Inventor Professional
2008 / Autodesk Inventor Professional 2009
Autodesk Inventor Professional for Simulation 11.x / Autodesk Inventor
Simulation 2008 / Autodesk Inventor Simulation 2009
Autodesk Inventor Professional for Routed Systems 11.x / Autodesk
Inventor Routed Systems 2008 / Autodesk Inventor Routed Systems 2009
AutoCAD Mechanical 2008 / AutoCAD Mechanical 2009
Mechanical Desktop 2008 / Mechanical Desktop 2009
AutoCAD Electrical 2008 / AutoCAD Electrical 2009
AutoCAD 2008 / AutoCAD 2009
AutoCAD P&ID 2008 / AutoCAD P&ID 2009
AutoCAD Map 2008 / AutoCAD Map 2009
Autodesk Civil 3D 2008 / AutoCAD Civil 3D 2009
Autodesk Architectural 2008 / AutoCAD Architectural 2009
AutoCAD MEP 2008 / AutoCAD MEP 2009
Autodesk Viz 2008 / Autodesk Viz 2009
Autodesk 3ds Max 2009
Autodesk 3ds Max Design 2009
And, do note that for 3ds Max and 3ds Max Design Users: You must install the
Autodesk Vault 2009 Plug-in for 3ds Max 2009 from the 3ds Max or 3ds Max
Design 2009 Installation Wizard to make Vault available from within the
product.
And, "AutoCAD Land Desktop Companion 2008" is not listed as the compatible
software.
If the vault add-in is not appearing in your ADSK product, you could re-add
them with these steps:
a. via Add\Remove Program > Autodesk Vault 2009 > Add/Remove features, and
b. select features to install, e.g. 'AutoCAD 2009 Add-in', or 'Autodesk
Inventor 2009 add-in'.
Hope it helps.
Rgds,
Chear Huat.
"OwenW" wrote in message news:5985243@discussion.autodesk.com...
> Thanks for the info, Dave!
> Which Vault clients can I use for:
> AutoCAD 2008
> AutoCAD MEP 2008
> AutoCAD Architecture 2008
> AutoCAD Civil 3D 2008
> Some of these have the Vault client option in the deployment wizard. If I
> modify the deployments, can I get the installations updated by re-running
> the deployment on the target PCs, or will I have to install individually?
> Thanks!
> Owen
> POET Design & Construction
