Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Moving Vault Basic ADMS 2015
4 REPLIES 4
448 Views, 4 Replies
Windows 8, Vault Basic 2015, Inventor 2015.
I need to move the ADMS from my machine to a stand alone machine over the network. In ADMS I see many options that look like what I want to do and it's overwhelming.
Under Tools: Backup, Detatch Master Vault, Move Master Vault
Under Actions: Detatch, Move Database, Move File Store
I want all vault files and the vault itself to be moved
My Machine to Server to New Machine
I thought I could just back up the vault to the server, install Vault ADMS on the new machine and restore from the backup, but I'm not sure that will bring all the info with it.
Thanks for the help
Ed
4 REPLIES 4
Neil_Cross
Yea move it using backup and restore.
Go to your machine, open ADMS and do a manual backup.  This backs up literally everything, all vaults, files, users, settings, the lot.  Backs it all up into a folder that you specify.
Install ADMS onto the new machine, then go into that once it's installed and perform a restore.  To save yourself a load of hassle, move the backup to the new machine so it's on the same drive as the new ADMS, and restore from that local folder.
in reply to: Neil_Cross
thanks for the lightning fast response, much appreciated
Neil_Cross
No probs.
Keep the old Vault live on your machine whilst you're doing the restore, there's no problems with having the same Vault running on two different machines/servers.  Only issue is if someone checks work into the old Vault after you've done the backup.
Once you're happy the Vault is safely restored into the new machine, tested OK, you can then blitz it off your old PC.
paul.gunn
Hi Ed,
I would definitely recommend doing a backup on the old machine - then restoring to the new machine (as you suggest).
This will transfer all database and files - and is the easiest and most reliable approach.
Paul
