Yes. This should be discussed in the Managing Your Data guide. The easiest
thing to do is to "Export" the data files from the Content Center Library
Manager that's part of Inventor (it accesses the "INVENTORCONTENT"
database), to the MSSQL$AUTODESKVAULT\data directory, then "Attach" the
database using CCLM that's part of the Autodesk Data Management Server.
Jeff
"RobV" wrote in message
news:5146468@discussion.autodesk.com...
Vault 4 and Inventor 10
I have the server and client set up on the same machine. My Microsoft SQL
Server folder has subfolders called "MSSQL$AUTODESKVAULT" and
"MSSQL$INVENTORCONTENT".
I assume the first is my "server" and the latter is my "client". If I look
into my "client" location I see my
InventorStandardContent database. What are the steps to move this database
or any other database to the "server"? Could I manually move the mdf and
ldf files over to the other folder (MSSQL$AUTODESKVAULT) and then go into
the Content center and Add it back in?
Rob
