We are having another server and I am trying to move the vault to a new server. The old server is Vault 2013 I am also migrating to the new 2014 on the new server.
I have backed up the database and file store on the old server, then restored them to the new server and migrated the databases. This seems to have gone ok, but when I connect to the vault I don't see any of the files.
I can see the vault structure, just not the files.
If I look in the location of the file store on the hard drive the files are there, they just do not show in the vault client.
I have also tried connecting from Inventor. I can connect to the vault, but not open files and the "open from Vault" button is still greyed out.
Any help would be greatly appreciated.
Regards
Kenny Holmes
Did you make the backup using the ADMS-Console, and restore it to the new server with the ADMS-Console?
-Dave
Hi Dave,
Thanks for getting back to me.
Yes I backed up using the 2013 console on the old sever and restored to the new server with the 2014 console.
The backup and restore seemed to go ok, including migrating the databases.
The file store is in a different location than on the original server. I specified a new location when I did the restore. Is there any chance this could be a contributing factor?
Kenny
I restore backups and specify a different filestore location that the original system often, so I don't think that is the problem.
FYI - the filestore is not consulted when browsing files. Instead we use metadata about the files that is stored in the database.
There were some problems with .NET 4.5 that resulted in display issues, but I believe those were solved with 2013 SP1 and the fixes made it into 2014.
So unfortunately, I'm not sure what would be causing this - I recommend opening a case with product support.
-Dave
I seem to be having the same problem, except I am running the 2013 client. Does anyone know what the end result was for the product support case? Any help would be greatly appreciated.
I never found out how to get the files to show properly. I did confirm that the problem only happens on machines where the 2014 client had been installed. We were still using the 2013 client at the time. When both are installed the files do not show in the 2013 vault client. I don't believe the issue had anything to do with the server move, it was only related to the client machines.
I can't remember details, but I believe the issues were .net framework related.
If you use the newer client and you are having the same problem as I did them you should be fine.
Kenny
Have you installed 2013 SP1?
-Dave
Hello Kenny
Acctually I´m having exactly the same problem .
¿Could find a solution yet?
I´ll be very gratefull for your help.
Best regars,
Henry Gómez
Hello.
It´s solved.
The problem was we don't´n install the Service Pack 1 when add two new machines at the beginning of year.
In the other machines all works well.
Now it´s all OK.
Regards.
Henry Gómez
