Hello all,
I'm using Inventor for a couple of years now.
At the company where I work we also started with Autodesk Inventor and the Vault (2014).
So the Vault is also new for me.
I have (probably) a simple question...
I work in a production company. We have some machinery and storage items that is purchased (and will not change) e.g. AGV's, Storage platforms etc.
I drawn these in 3D and put it temporary in the Vault in a normal work folder with the idea to put this in a library folder later.
Some assemblies also consist content center files (beams, bolts), these are in the Vault allready.
Now the question is....How can I move the parts/assemblies from an normal working folder into a library folder?
Can't be difficult I guess... but I do not succeed.
Thanks in advantage.
You should be able to move the parts from Normal folder to Library folder. Ensure you set the right Inventor Project as current project. What is the error /issue you see while moving the parts?
