Dear,
I have question about DWF (generating during chec-in to Vault) from AutoCAD DWG opend in Inventor.
If I open AutoCAD DWG in Inventor so in drawing remaining model space (on picture in an attachement). If I check-in this drawing to Vault so DWF contain this model space (too in the attachement).
Do you know any working prcedure how check-in drawing from Inventor without generating DWF from model space (DWF contains only layout space?
Note: AutoCAD DWG has opened in Inventor becouse I want supplemet drawing with some view from Inventor's model.
My configuration:
Inventor 2011 SP3 CZ,
Vault Professiona 2011 CZ Update 2 with all hotfix,
Windows 7 CZ
Thank you for your request,
Petr Polivka
One way is to uncheck the "All Sheets" option from Publish Option for Inventor 2012 files and creating DWFs using "Job Processor". I tried that method and it did publish only the Layout. Please refer the attached DWF which I created using the above method.
