Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Missing Vault toolbar in ACad 14
2 REPLIES 2
FedotovAnton
272 Views, 2 Replies
Hello, On one of the PCs we're using there is no Vault toolbar in Autocad 2014. We've tried reinstal Vault and use "Add/remove components" option (Autocad Add-in is missing). What we have to do? Regards, Anton
Tags (3)
2 REPLIES 2
KooCheeKit
in reply to: FedotovAnton
For this case, the workaround should be using cuiload command and load the Vaac.cuix.
Sorry for the late reply.
CheeKit
Chee-Kit
Autodesk, Inc.
jlaidle1
You may also have to update the workspace within AutoCAD to include the Vault Ribbon Tab.
John Laidler
ITO - Application Management
Please use "Accept as Solution" & give "Kudos" if this response helped you.
