Michael,
I do not see the Connectivity.Common.Sharedlib.dll file - chances are
that is the missing dependency.
See if that file is in some other folder. Manually search your 123,
1234, etc. folders or use Windows Explorer to search for it. If it finds
one, copy it to your 12 folder.
It sounds like you have a lot of duplication of files. You might want to
uninstall everything, clean up those extra folders and start clean.
Is your Inventor Vault add-in working ok?
To answer an older question of yours--
> Is there supposed to be a Vault menu item in the File menu pulldown list?
Yes. That is one of the things that the vaac_startupUI module does. You
will know it is loading when you see that menu.
-dave
Michael Youla wrote:
> Thanks, David!
> I've attached the Dependencywalker file generated by that program - I can't make much sense of it, and I wholehaeartedly agree that I shouldn't have to go through this. I've also attached a txt file generated by a dos dir of the directory in question. I also have a call into my VAR, but it doesn't seem hopeful- they said thety would cal back in a couple of hours 2 days ago..
> Volume in drive C has no label.
> Volume Serial Number is 0885-FA21
> Directory of C:\Program Files\12
> 02/14/2006 07:35 PM
> 02/14/2006 07:35 PM ..
> 03/12/2005 12:11 AM 180,224 Connectivity.AutoCAD.Forms.dll
> 03/12/2005 12:48 AM 135,168 Connectivity.Common.dll
> 03/10/2005 02:39 PM 241,664 Connectivity.Common.Vault.dll
> 03/11/2005 11:49 PM 32,768 Connectivity.Proxies.Admin.dll
> 03/11/2005 11:49 PM 135,168 Connectivity.Proxies.Document.dll
> 03/11/2005 11:47 PM 28,672 Connectivity.Proxies.ERP.dll
> 03/11/2005 11:47 PM 106,496 Connectivity.Proxies.Item.dll
> 03/11/2005 11:49 PM 32,768 Connectivity.Proxies.KnowledgeVault.dll
> 03/11/2005 11:49 PM 24,576 Connectivity.Proxies.Security.dll
> 02/14/2006 07:35 PM 0 dir.txt
> 01/10/2006 08:59 PM enu
> 03/10/2005 02:42 PM 282,624 exac_esw.arx
> 03/10/2005 02:42 PM 31,744 exac_eswRes.dll
> 03/10/2005 02:40 PM 323,584 exac_service.arx
> 03/12/2005 12:48 AM 90,112 exac_util.dll
> 03/10/2005 02:41 PM 163,840 exac_vaultUI.dll
> 03/10/2005 02:42 PM 69,632 exac_vaultUIRes.dll
> 01/10/2006 08:59 PM Help
> 03/10/2005 02:14 PM 26,920 VaAc.cui
> 02/11/2006 07:08 PM 41,140 VaAc.mnr
> 03/10/2005 02:14 PM 3,126 VaAcAttachFromVault_lg.bmp
> 03/10/2005 02:14 PM 822 VaAcAttachFromVault_sm.bmp
> 03/10/2005 02:14 PM 3,126 VaAcCheckinFolder_lg.bmp
> 03/10/2005 02:14 PM 822 VaAcCheckinFolder_sm.bmp
> 03/10/2005 02:14 PM 3,126 VaAcCheckIn_lg.bmp
> 03/10/2005 02:14 PM 822 VaAcCheckIn_sm.bmp
> 03/10/2005 02:14 PM 3,126 VaAcCheckOut_lg.bmp
> 03/10/2005 02:14 PM 822 VaAcCheckOut_sm.bmp
> 03/10/2005 02:14 PM 3,126 VaAcLogIn_lg.bmp
> 03/10/2005 02:14 PM 822 VaAcLogIn_sm.BMP
> 03/10/2005 02:14 PM 3,126 VaAcLogOut_lg.bmp
> 03/10/2005 02:14 PM 822 VaAcLogOut_sm.bmp
> 03/10/2005 02:14 PM 3,126 VaAcOpen_lg.bmp
> 03/10/2005 02:14 PM 822 VaAcOpen_sm.bmp
> 03/10/2005 02:14 PM 3,126 VaAcUndoCheckOut_lg.bmp
> 03/10/2005 02:14 PM 822 VaAcUndoCheckOut_sm.bmp
> 03/12/2005 12:23 AM 557,056 VaAc_addin.arx
> 03/10/2005 02:42 PM 65,536 vaac_addinRes.dll
> 03/10/2005 02:42 PM 114,688 VaAc_Mech.arx
> 03/12/2005 12:29 AM 290,816 VaAc_service.arx
> 03/12/2005 12:29 AM 516,096 vaac_SharedLib7_0.dll
> 03/10/2005 02:42 PM 98,304 VaAc_startupUI.arx
> 03/10/2005 02:41 PM 8,704 vaac_startupUIRes.dll
> 41 File(s) 3,629,884 bytes
> 4 Dir(s) 31,802,445,824 bytes free
