Hi, Dear All,
We upgrade Vault Professional 2012 to Vault 2014, but faied with the following error message on the server.
WebHost failed to process a request. Sender Information: System.ServiceModel.ServiceHostingEnvironment+HostingManager/6451435 Exception: System.ServiceModel.ServiceActivationException: The service '/AutodeskDM/Services/InformationService.svc' cannot be activated due to an exception during compilation. The exception message is: Memory gates checking failed because the free memory (301678592 bytes) is less than 5% of total memory. As a result, the service will not be available for incoming requests. To resolve this, either reduce the load on the machine or adjust the value of minFreeMemoryPercentageToActivateService on the serviceHostingEnvironment config element.. --->
On the Vault client, the error message that it's not compatible with the server.
But if we re-started the server, it's ok. but the next day the same problem message will appeard.
the system is: Windows 2008 Server 64bit, 8GB Memory. only SQL 2008 R2 and Vault profesional server installed.
Thanks for any inputs.
Gengyun
