Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Markup & Measure toolbar missing in Vault preview
16 REPLIES 16
Message 1 of 17
VinceBalge
6165 Views, 16 Replies
The Markup Toolbar has disappeared on some workstations but not all.
After migrating to 2014 some strange behavior has started.
When I first installed VP2014 & IV2014 everything seamed to work fine. After migrating the rest of the group some people commented that they couldn't see the Markup Toolbar when using the ECO process to review files.
normaltoolbar.png is what I would expect to see as the toolbar
Everthing worked and I could create markups Then I got this error.
Now Toolbar is missing.
toolbar missing markup.PNG what I see now for the toolbar
I've witnessed this on serveral machines including my own. I've uninstalled DesignReview & Trueview then reinstalled from the Autodesk website without solving the issue.
If I open DesignReview by it's self the Markup toolbar is there.
Vault Pro 2014 with SP1
Inventor PDSU 2014
Vince
Tags (1)
16 REPLIES 16
Message 2 of 17
ihayesjr
in reply to: VinceBalge
Try starting the Vault client as an Administrator.  Right click on the Vault client short-cut and select "Run as Administrator" and see if the toolbar appears.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 3 of 17
VinceBalge
in reply to: ihayesjr
Thanks for the reply;
I've logged into Vault client as administrator with the same results.
I then logged on to computer as administrator & the Vault Client as administrator with same result.
I've done a repair of the Vault installation from the control panel & re-installed SP1, still no Markup Toolbar.
Vince
Message 4 of 17
mbodnar
Hi
I am experincing the same issue here. Vault Pro 2014 + SP1 on Windows 8. Design Review 2013, and Inventor 2014 + Update 2.
I tried a repair and re-install of Vault client, Design Review and True View
Mark Up tools come up when opening full version of Design Review but DO NOT come up in the ECO window under files tab, preview
Max
Message 5 of 17
msd_inouem
in reply to: mbodnar
Hi VINCEBALGE4109,
Are you running VP 2014 SP1 on Windows 8?
I can reproduce it on Windows 8, not Windows 7.
mbodnar
Can you test on Windows 7?
Makoto Inoue
Message 6 of 17
VinceBalge
in reply to: msd_inouem
Server is running on Windows Server 2008 R2 Standard
Clients are all running Windows 7 SP1 64bit
Vault Pro has SP1 installed.
Vince
Message 7 of 17
mbodnar
Hi
On windows 7 here toolbars appear OK. I have only noticed it dissapear on Window 8
Max
Message 8 of 17
Duckjae_Lee
My system also shows me almost same symptoms.
But i use windows7.
Sys info...
Windows 7 Enterprise K service Pack1 / 64bit
Vault Pro 2014 SP1 (Build 18.1.8.0)
AutoCAD M 2014
Is there any solution for me, or is there any vault option to display the menu?
Thanks and regards,
Jerry
Message 9 of 17
msd_inouem
Exit all application, and please run repaire installation for Autodesk Design Review 2013.
How about toolbar?
Makoto
Makoto Inoue
Message 10 of 17
Duckjae_Lee
Hi Makoto,
Thank you for your reply.
I did it with your advise, but same.
Jerry
Message 11 of 17
mbodnar
Hi Makoto
Same here, a repair or/and un-install/re-install of Design Review 2013 makes no difference on Windows 8
Max
Message 12 of 17
VinceBalge
Has anyone come up with the solution to this. We're still seeing this behavior.
I'm setting existing user up with new computer. When I installed Vault & Design Review as the administrator everything works a you would expect.
When the user logs in the markup toolbar is missing. If they go back to their old computer toolbar is there.
The solution put forward was to delete the VaultCommon, Productstream and Autodesk Vault Professional 2014 folders from AppData in their user profile.
That does nothing for the problem. I've also tried deleting anything that looks like it could be related to Design Review from the users profile in AppData.
If I have the User log in to my own computer the toolbar is missing. I works correctly when I'm logged into my own computer.
It has to be something in the users profile or the registry, but I can't locate it. We're not using roaming profiles.
Vault 2014 Pro Build 18.100.12.0 Subscription Release 1
Design Review 2013
PDSP 2014
Vince Balge
Tags (1)
Message 13 of 17
pcetnar
Two of my customers are currently experiencing this issue as well (both 25+ seats of Vault Pro).  I logged a case with Autodesk a few months ago and received a response that it was sent to the development team.  I hope a fix is released soon as the ECO tools were a primary reason they upgraded to Pro.
Paul
Message 14 of 17
bharath.kumar99
in reply to: pcetnar
Hi All - We've identified a root registry key responsible for showing up the Markup components, the markup tool( but the ADR in general) relies on one of the core microsoft component "Preview Handler Surrogate Host".
Please grant full permission to the user/group on the key "HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node", the subkeys underneath controls the visibility of the Markup component.
Bharath Kumar
Message 15 of 17
Thank You! that fixed the problem.
Vince
Message 16 of 17
pcetnar
in reply to: bharath.kumar99
Unfortunately these steps didn't fix the solution for my customer.  Would you happen to know of any other culprits that could be causing their ECO toolbars to be missing?
Paul Cetnar
Message 17 of 17
VinceBalge
Hi Paul;
The only other thing that seemed to affect the markup toolbar is user accounts and permissions.
I've listed all the things I tried before the wow6432 fix here.
http://forums.autodesk.com/t5/Vault-General/Change-Order-Markup-tool-missing/td-p/4385980/page/2
Vince Balge
Senior Specialist - CAD Systems
ATCO Emissions Management
The information transmitted is intended only for the addressee and may contain confidential, proprietary and/or privileged material. Any unauthorized review, distribution or other use or the taking of any action in reliance upon this information is prohibited. If you receive this in error, please contact the sender and delete or destroy this message and any copies.
