Hi Folks,
I'm working on mapping user defined properties from Vault to AutoCAD block attributes.
Everything works fine untill I create an AutoCAD block using a block property table in the AutoCAD block editor.
Somehow it loses it's "connection" with Vault......does this sounds familliar to other people?
Using Vault Professional 2014 and Civil 3D 2014.
Thanks!
Remco
Hi Remco,
what do you exactly mean by "loses connection" Do you have an example? Screenshots?
If you are using properties from an AutoCAD block: have you added the blocks in the ADMS console on "Index Block attributes"?
