I'm facing a problem by mapping the properties in Vault and my parts.
I have defined a huge number of properties in our Vault database and some of them map their information to one single property.
To give an example: i have two properties called "VALVE TYPE 1" and "PUMP TYPE 1".
Both of them are mapping to 1 Custom Property called "TYPE 1"
Since we are talking about 100+ custom properties i don't want to have an entire list of empty custom properties in my parts so i figured to let them get created when you fill it in from withing the data card.
Now, and here i'm facing the problem, when you do this with a property that is only used one on one, then it works,
but when i have a property such as the example above, connected to several properties, the custom property is not being created.
Does anybody have a solution for this apart from having every property created from the Vault (having empty custom properties in your parts) or having a one on one relation between the Vault property and iProperty.
Thanks in advance!
Solved by cbenner. Go to Solution.
Not sure if this is intended functionality, but in my experience you really can't have more than one Vault property mapping to the same Custom property... I'm making some assumptions here since your original post was lean on information... I'm assuming you are using Inventor? What releases do you have?
Every time I have found 2 properties in Vault mapped to the same iproperty in IV, or custom props in Acad... these properties have failed to be created. I'm guessing this is intentional. My advice would be to avoid this scenario.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I'm sorry i've been unclear somewhat on the problem, but indeed your assumption is right.
I wanted to reduce the number of custom properties by having Vault properties map to the same property such as these.
I'm using Vault Collaboration and Inventor 2011.
