Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Main Menu Disappeared?
13 REPLIES 13
Message 1 of 14
djohnson1976
4562 Views, 13 Replies
We have had a user who has had her main menu (accross the top) disappear. We can't find a way to get it back. Any ideas?
13 REPLIES 13
Message 2 of 14
Madhan_T
in reply to: djohnson1976
Please try the following and let me know if that works.
1. Close Productstream 2008 Application
2. Browse to %appdata%\Autodesk\
3. Rename "Productstream 2008" to "OLD_Productstream 2008"
4. Launch Products 2008 Application
HTH,
Madhan
Madhanagopal Thiruvenkatachalam
Principal Engineer
Engineering Escalation Team
Autodesk, Inc.
Message 3 of 14
If you are talking about the main grid area...sometimes the bar that splits
the Uses,Where Used, View section from the main pane gets moved all the way
to the top. If you move your mouse just below were the toolbars end you will
see your mouse change over to show you can select and you can then grab the
bar and move it back down. After you do that and close PS should remember
the location the next time its opened. If this doesn't help you can also try
what Madhan suggested.
"djohnson1976" wrote in message news:5791392@discussion.autodesk.com...
Message 4 of 14
in reply to: Madhan_T
I'm having the same issue as djohnson1976 reported back in 2007, my main menu bar has gone missing.  I am however using Vault Pro 2012.
I can add all the commands back into a custom toolbar, however, this is an undesirable workaround compared to the standard main menu toolbar.
I'm not sure how it happened.
I'm thinking of uninstalling Vault Client, and doing a reinstall, however I don't want to have to do that.
Help?
Message 5 of 14
Andy.Spivey
Can you post an image of what you are seeing?
Without seeing a screen shot, you can most likely reset it by doing a right click on the menu, and select Customize.
Then select the menu in question and click "reset"
Andy Spivey
SQA Engineer
Message 6 of 14
in reply to: Andy.Spivey
Thanks for the reply, here's what I'm looking at. Notice how the main menu tool bar isn't there (the one with file, edit, view, go, tools, actions, help).  When I do as you say, and reset the main menu, nothing happens... the main menu bar doesn't reappear.
Message 7 of 14
Redmond.D
Try this:
  1. Exit the Vault client.
  2. Go to C:\Users\[your username]\AppData\Roaming\Autodesk\Autodesk Vault Professional 2012\Objects
  3. Delete Menus.xml
  4. Restart the Vault client.
Doug Redmond
Software Engineer
Autodesk, Inc.
Message 8 of 14
in reply to: Redmond.D
Thanks! Fixed it.
Message 9 of 14
toolrite
I'm having this same problem in mechanical desk top 2007.
Anyone have a idea to help me.
Message 10 of 14
Andy.Spivey
in reply to: toolrite
toolrite,
The same fix may apply for MDT, though I am not sure as I am not familiar with the product.
Try this:
  1. Exit MDT.
  2. Go to C:\Users\[your username]\AppData\Roaming\Autodesk\%MDT 2007%\
  3. Copy the contents to a new location as a backup.
  4. Delete the contents of C:\Users\[your username]\AppData\Roaming\Autodesk\%MDT 2007%\
  5. Restart MDT.
I hope that helps, if not, check the MDT forums here:
http://forums.autodesk.com/t5/Autodesk-Mechanical-Desktop/bd-p/89
Andy Spivey
SQA Engineer
Message 11 of 14
autodesk
Unfortunately I'm having the same issue with the main menu, however I cannot find the following folder:
Message 12 of 14
Andy.Spivey
in reply to: autodesk
Kirk,
That will be the folder structure of either Windows Vista or 7 - please note that the folder AppData is hidden, so either you will need to have hidden folders exposed or manually type in the folder name under you User's profile.
I hope that helps.
Andy Spivey
SQA Engineer
Message 13 of 14
allisonh
Thanks for the solution.  Any idea what causes this to happen?
Message 14 of 14
Andy.Spivey
in reply to: allisonh
Hi AllisonH - unfortunatly I am unaware of any single cause.  My thoughts are that the files are possible manipulated outside of the product (maybe an AV scan?) causing the corruption - but no real facts to support it.
-Andy
Andy Spivey
SQA Engineer
