Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Login to Reference Repair Utility
11 REPLIES 11
Message 1 of 12
petrxn
748 Views, 11 Replies
I am not able login to server with new Repair Utility (vault 2013 SP1). I get the error "Only users with administrator role can run this application.". What can be wrong? The username/password is correct, this is my vault server  account with role admin. I am afraid that problem could be with localization of vault server. We use CZE localization. Could somebody with localized vault 2013 server check and confirm taht is able to login with this utility?
Many thanks
Petr
11 REPLIES 11
Message 2 of 12
chearhuat
in reply to: petrxn
Hi Petrxn,
Reference Repair Utility could only work with Server with the respective Update 1.
Could you help to validate this?
Thanks.
Regards
Chear Huat
Chear Huat
SQA Analyst
DLS- Data Management
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
Message 3 of 12
petrxn
in reply to: petrxn
Thank you, this update is already installed on server. Build 17.1.16.0 Update 1. I am able login with Vault client (the same build/update) but not with this utility.
Message 4 of 12
xavier_dumont1
in reply to: petrxn
There is a bug in the utility. It works only if the ADMS is an English ADMS.
If the ADMS is localized, it doesn't work because the display name of the role name is not "Administrator".
I already log this by Autodesk.
Message 5 of 12
achintam
in reply to: petrxn
Thanks for reporting this.  We found that in some localized environments it is not possible to log into Vault from the Reference Repair Utility.  We are working on a fix for this issue.
Anil Chintamaneni (Autodesk)
Message 6 of 12
petrxn
in reply to: petrxn
Thank you,
hope it will be corrected soon.
Petr
Message 7 of 12
marina.collet
in reply to: petrxn
The last post was 2 months ago... Any news about a fix for the localized Vaults?
Message 8 of 12
denis.bourasseau
in reply to: achintam
No solution yet?
I want to use this tool before performing a purge. Our database is growing and I can't do anything to fix it.
Message 9 of 12
petrxn
in reply to: denis.bourasseau
It seems that this is complicated task for Autodesk Smiley Sad
I am also still waiting for an solution....
Petr
Message 10 of 12
xavier_dumont1
in reply to: petrxn
Yes: replace Roles.RoleName="administrator" by Roles.SystemName="administrator"
=> 3 month of works 😉
No, I think Autodesk want to publish an hotfix with others improvements in order to fix the initial purge bug in Vault Basic by example (actually, the Repair Utility can't fix the original bug because you can't give a child newer than the parent as references...)
But hope this fix will be available very soon !
Message 11 of 12
DRudaz
in reply to: xavier_dumont1
The last post was 1 month ago... Any news about a fix for the localized Vaults?
Message 12 of 12
JohnHuber
in reply to: DRudaz
The hotfixes have been posted for download;
We are working on additional updates.
John Huber
Engineering Escalation Team
Autodesk, Inc.
