Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Loading Vault Basic Server 2015 on the same machine as Inventor and Vault client
3 REPLIES 3
Bruce-1008
592 Views, 3 Replies
Does anyone one have the step by step instructions for loading Vault Basic Server 2015 on the same machine as Inventor 2015 and Vault Client 2015? The machine operating system is Windows 7 Professional. My Server is now too old and I want to do this as an interim fix until Autodesk make Vault Basic Server available on the cloud as a reasonable price.
Regards
Bruce
3 REPLIES 3
DarrenP
in reply to: Bruce-1008
Regards
Bruce
i suggest going through this guide 2014 version should be enough since it has the same system requirements as 2015
http://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
as far as Cloud offering of Vault i doubt this is going to happen any time soon
DarrenP
DarrenP
in reply to: DarrenP
if you plan to run sql 2008 express from the vault install then there is nothing really to do
during the vault install it will run the pre checks on your system to make sure all the necessary settings IIS for example is set up correctly
DarrenP
DarrenP
if you are going to AU this year
you may want to look into this class
PL6015-P - Every Silver Lining Has a Vault in the Cloud
Primary track:
PLM and Data Management
Learn how to use Microsoft Azure to host Vault software
Learn how to use Amazon Cloud to host Vault software
Learn the license requirements when using a hosted environment
Learn how to connect a local File Server with a hosted Vault Server
IT Manager/CAD Equipment Manager
Vault for Admin
None
Lecture
1 hour
DarrenP
