I have problem with mapping the library with Autoloader. I have there no options to map with libraries folder, only folder Design is available.
I have libraries such as iPart in Inventor.
Anyone know the solution?
Ensure the project that you selected has the right library setting. You can also refer the following post which may help you.
http://forums.autodesk.com/t5/Vault-General/Change-Autoloader-default-folder/td-p/3296285
Let me know if you need any further help.
