What is the build number for Vault 2014 for Workgroups?
About currently reports:
Autodesk Vault Workgroup
Build 18.1.8.0
Update1
Do I have the latest and greatest currently installed? Is the report correct if Service Pack 1 has been installed?
Thank you!
Solved by Senthil_Kumar. Go to Solution.
Jim,
Yes. That is the latest build. And Yes, Update 1 means SP1.
You can also use this link to verify what you have.
http://crackingthevault.typepad.com/crackingthevault/2013/05/vault-build-numbers.html
Hope this helps.
