I have a vault (2009) which currently has a database size of 1.2GB - well within limits i thought. I got to work a few days ago to find the server had 0 space on the Vault partition.
On investigating the problem i found that KnowledgeVaultMaster has exceeded 4GB, which has caused over 60,000 errors in event manager regarding license issue. I suspect that this error is being written out to KnowledgeVaultMaster_log, which is now 130GB in size!
I manage a network of more than a dozen engineers, which now do not have Vault.
My question is should the KnowledgeVaultMaster database be exceeding 4GB if our main Vault is only 1.2GB? If so i have been looking at the wrong database size information (ADMS console) and been very misled.
I have a critical support request with Autodesk, but i haven't had a response since early yesterday and this is a serious situation.
I know that the limitation can be removed by installing full SQL. If this is the correct option, which version should i use / purchase. Also, i am mindfull that we are close to 2010 release. Are there any changes that will be relevant in the new release?
Many thanks,
Dave Mason
