Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Job Server API Sample: How to run the "FolderPublish" from a lifecycle event?
8 REPLIES 8
Message 1 of 9
bredo
2120 Views, 8 Replies
Hi
I'm new to the Job Server API (worked a lot with Inventor and Vault API though) and need some help to get this kickstarted.
I'm currently trying to get the "FolderPublish" sample files that comes with the SDK to run from a lifecycle event. I've installed the files as instructed in the readme. The "Queue Publish Job" is present in the right click menu on files in Vault Pro 2012. If I select this action the job is sent to the Job Server queue and executed without errors. Using the "LifecycleEventEditor" I've added the same job to a few lifecycle transitions. When I then run a couple of files through those transitions, the job still get added to the Job Server queue, but this time it produces an error when processed: "The given key was not present in the dictionary."
I've tried searching this forum and googled for solutions. I've also tried to get some more information about the "LifecycleEventEditor" tool itself, but have been unsuccessfull.
My guess is that some of the attributes are different when the job is triggered from a lifecycleevent. The code should be available in the SDK, but I'll paste it here anyway:
FolderPublishJobHandler.vb
Imports Autodesk.Connectivity.JobProcessor.Extensibility
Imports Autodesk.Connectivity.WebServices
Imports Autodesk.Connectivity.WebServicesTools
Public Class FolderPublishJobHandler
	Implements IJobHandler
	Private Property TargetFolder() As String
		Get
			Return m_TargetFolder
		End Get
		Set
			m_TargetFolder = Value
		End Set
	End Property
	Private m_TargetFolder As String
	Public Sub New()
		TargetFolder = "C:\PublishFolder\"
	End Sub
	#Region "IJobHandler Members"
	Public Function CanProcess(jobType As String) As Boolean Implements IJobHandler.CanProcess
		If jobType.ToLower().Equals("MyCompany.File.Publish".ToLower()) Then
			Return True
		End If
		Return False
	End Function
	Public Function Execute(context As IJobProcessorServices, job As IJob) As JobOutcome Implements IJobHandler.Execute
		Dim fileMasterId As Long = Convert.ToInt64(job.Params("FileMasterId"))
		Try
			Dim credentials As New UserIdTicketCredentials(context.VaultContext.RemoteBaseUrl.ToString(), context.VaultContext.VaultName, context.VaultContext.UserId, context.VaultContext.Ticket)
			Using serviceManager As New WebServiceManager(credentials)
				' Retrieve the file object from the server
				Dim file As File = serviceManager.DocumentService.GetLatestFileByMasterId(fileMasterId)
				' Download and publish the file
				Publish(file, serviceManager)
			End Using
			Return JobOutcome.Success
		Catch
			Return JobOutcome.Failure
		End Try
	End Function
	#End Region
	Private Sub Publish(file As File, serviceManager As WebServiceManager)
		Dim targetDir As New System.IO.DirectoryInfo(TargetFolder)
		If Not targetDir.Exists Then
			targetDir.Create()
		End If
		Dim bytes As Byte()
		Dim fileName As String = serviceManager.DocumentService.DownloadFile(file.Id, True, bytes)
		Dim fileFullName As String = TargetFolder & fileName
		System.IO.File.WriteAllBytes(fileFullName, bytes)
	End Sub
End Class
 QueuePublishJobCommandExtension.vb
Imports System
Imports System.Reflection
Imports Autodesk.Connectivity.Extensibility.Framework
Imports Autodesk.Connectivity.Explorer.Extensibility
<Assembly: AssemblyCompany("Autodesk")>
<Assembly: AssemblyProduct("JobProcessorApiSamples")>
<Assembly: AssemblyDescription("A sample that queues and handles a job")>
<Assembly: ApiVersion("4.0")>
<Assembly: ExtensionId("0C22C400-9002-49ef-95B9-9B7B97A32A0D")>
Public Class QueuePublishJobCommandExtension
	Implements IExtension
	'private JobService mJobSvc;
	Private m_serviceManager As WebServiceManager
	Public Sub QueuePublishJobCommandHandler(s As Object, e As CommandItemEventArgs)
		' Queue a ShareDwf job
		Const  PublishJobTypeName As String = "MyCompany.File.Publish"
		Const  PublishJob_FileMasterId As String = "FileMasterId"
		Const  PublishJob_FileName As String = "FileName"
		For Each vaultObj As ISelection In e.Context.CurrentSelectionSet
			Dim paramList As JobParam() = New JobParam(1) {}
			Dim masterIdParam As New JobParam()
			masterIdParam.Name = PublishJob_FileMasterId
			masterIdParam.Val = vaultObj.Id.ToString()
			paramList(0) = masterIdParam
			Dim fileNameParam As New JobParam()
			fileNameParam.Name = PublishJob_FileName
			fileNameParam.Val = vaultObj.Label
			paramList(1) = fileNameParam
			' Add the job to the queue
			m_serviceManager.JobService.AddJob(PublishJobTypeName, [String].Format("Publish File - {0}", fileNameParam.Val), paramList, 10)
		Next
	End Sub
    #Region "IExtension Members"
	Public Function CommandSites() As IEnumerable(Of CommandSite) Implements IExtension.CommandSites
		Dim sites As New List(Of CommandSite)()
		' Describe user history command item
		Dim queuePublishJobCmdItem As New CommandItem("Command.QueuePublishJob", "Queue Publish Job")
		queuePublishJobCmdItem.NavigationTypes = New SelectionTypeId() {SelectionTypeId.File}
		queuePublishJobCmdItem.MultiSelectEnabled = False
		AddHandler queuePublishJobCmdItem.Execute, AddressOf QueuePublishJobCommandHandler
		' deploy user history command on file context menu
		Dim queuePublishContextMenu As New CommandSite("Menu.FileContextMenu", "Queue Publish Job")
		queuePublishContextMenu.Location = CommandSiteLocation.FileContextMenu
		queuePublishContextMenu.DeployAsPulldownMenu = False
		queuePublishContextMenu.AddCommand(queuePublishJobCmdItem)
		sites.Add(queuePublishContextMenu)
		Return sites
	End Function
	Public Function DetailTabs() As IEnumerable(Of DetailPaneTab) Implements IExtension.DetailTabs
		Return Nothing
	End Function
	Public Sub OnLogOn(application As IApplication) Implements IExtension.OnLogOn
		m_serviceManager = New WebServiceManager(New UserIdTicketCredentials(application.VaultContext.RemoteBaseUrl.ToString(), application.VaultContext.VaultName, application.VaultContext.UserId, application.VaultContext.Ticket))
	End Sub
	Public Sub OnLogOff(application As IApplication) Implements IExtension.OnLogOff
		m_serviceManager = Nothing
	End Sub
	Public Sub OnShutdown(application As IApplication) Implements IExtension.OnShutdown
		' NoOp;
	End Sub
	Public Sub OnStartup(application As IApplication) Implements IExtension.OnStartup
		' NoOp;
	End Sub
	Public Function HiddenCommands() As IEnumerable(Of String) Implements IExtension.HiddenCommands
		Return Nothing
	End Function
	#End Region
End Class
Any help or pointers to documentation\example code would be greatly appreciated.
Regards
Bredo Norhall
Edit: Pasted the entire code into the post
8 REPLIES 8
Message 2 of 9
bredo
in reply to: bredo
Hi again
Helps to get the question out there Smiley Happy
Just found something that I believe will get me going again.
As I understand "job.Params" only contain "FileId" and "LifeCyleTransitionId" when job is created from a lifecycletransition. Edited the code accordingly, and it now ran as it should.
Message 3 of 9
Redmond.D
in reply to: bredo
I think this page helpful:  http://justonesandzeros.typepad.com/blog/2012/04/lifecycle-event-job-parameters.html
Doug Redmond
Software Engineer
Message 4 of 9
bredo
in reply to: Redmond.D
Thanks a lot Smiley Happy
That will defenately help me along.
Message 5 of 9
vandargo
Hi There,
  I know this thread is a couple years old, but I'm coming across the exact same situation mentioned above.
  I have a custom job that works when run on a file in the vault, but not when run as a lifecycle event.  And I get the same error message.
  I see that the issue has been resolved, but could you please be more specific about how to resolve it?
I'm working with Vault Pro 2015.
Thanks!
V.
Message 6 of 9
bredo
in reply to: vandargo
Hi
My issue was that I expected to recieve the "FileMasterID" (se my code example), but the only thing passed from a lifecycle event was the "FileID". Once I worked around that limitation I got it working. Dont know if the same is true for 2015 though.
Message 7 of 9
vandargo
in reply to: bredo
Thanks for the quick response bredo!
So, reading the thread, I gathered that was the issue, but I was hoping to find out how to specifically work around the issue.
This is the original line (as it still shows up in the SDK samples, but I gather it is not passing anything...
Per the responses above, I tried the following...
Dim fileMasterId As Long = Convert.ToInt64(job.Params("FileId"))
and...
Dim fileMasterId As Long = Convert.ToInt64(job.Params("EntityId"))
with no perceived success.  So, it seems I am missing something obvious, and would appreciate knowing the work-around you came up with.
Thanks!
V
Message 8 of 9
bredo
Hi again
Sorry I didn't explain better 🙂 Anyway here is the code I used. Guess it could use some optimization, but it gets the job done. I've left the original line in the code, just commented it out for reference.
        Public Function Execute(ByVal context As IJobProcessorServices, ByVal job As IJob) As JobOutcome Implements IJobHandler.Execute
            'Dim fileMasterId As Long = Convert.ToInt64(job.Params("FileMasterId"))
            Dim fileId As Long = Convert.ToInt64(job.Params("FileId"))
            Dim fileIds As Long()
            ReDim fileIds(0)
            fileIds(0) = fileId
            Try
                    Dim file As Autodesk.Connectivity.WebServices.File() = serviceManager.DocumentService.GetLatestFilesByIds(fileIds)
                    Publish(file(0), serviceManager)
                End Using
            Catch
                ' Closes Inventor session
                _invApp.Quit()
            End Try
        End Function
  I dont know why the command you tried don't seem to pass a value, as it seems identical to what I'm doing.
Regards
Bredo
Message 9 of 9
vandargo
I've found a solution that works for me for now, I'll just lay it out here for any code hunters from the future.
I replaced this line...
Dim filemasterid As Long = Convert.ToInt64(job.Params("FileMasterId"))
with this line...
Dim EntityId As Long = Convert.ToInt64(job.Params("EntityId"))
and this line...
Dim file As ACW.File = context.Connection.WebServiceManager.DocumentService.GetLatestFileByMasterId(filemasterid )
with this line...
Dim file As ACW.File = context.Connection.WebServiceManager.DocumentService.GetFileById(EntityId)
and the function ran through as desired.
Thanks for your help bredo,
V.
