Vault General Discussion
Valued Contributor
5 Kudos
Post 1 of 4
Job Processor Vault 2012 and User Profiles
168 Views, 3 Replies
10-04-2011 08:38 AM
Hello All,
  I have a client that is using Vault Professional 2012 and decided to utilize Job Server.  When they initiated Job Processor on the defined workstations, they did so while logged in under their respective domain accounts.  Since then, they have lost some of the buttons on the Vault tab in Inventor 2012.  When someone else logs into the workstation, all the buttons on the Vault tab are there.
  So obviously, initiating Job Processor has somehow affected their user profile.  Does anyone know how to resolve this?  How can I prevent this from happening again?
Thomas Fitzgerald
Thomas Fitzgerald
Technical Consultant
Autodesk Consulting
262.422.2519
Valued Contributor
5 Kudos
Post 2 of 4
Re: Job Processor Vault 2012 and User Profiles
10-04-2011 10:12 AM in reply to: thomas.fitzgerald
Nevermind.  The answer was in this post:
http://forums.autodesk.com/t5/Autodesk-Vault/CANNOT-INSTALL-VAULT-PRO-ADD-IN-FOR-INVENTOR-2012/td-p/...
Thomas Fitzgerald
Autodesk Consulting
262.422.2519
Distinguished Contributor
10 Kudos
Post 3 of 4
10-05-2011 11:12 PM in reply to: thomas.fitzgerald
Unfortunately, the same problem will return again.
When the Job Processor starts Inventor to process files, it uses a lightweight userprofile for Inventor (no plugins). If Inventor crashes while publishing a DWF, the user profile will not be reset.
The best option is to run Job Processor on a dedicated workstation.
*Expert Elite*
391 Kudos
Post 4 of 4
10-08-2011 02:07 PM in reply to: hans.martin.haga
Except Autodesk expect you to use another license of Inventor to do that. So its not the best way at all for smaller design offices. It all well and good for large install bases, and extra license of Inventor is a small percentage of their annual costs etc..
Cheers
Scott Moyse
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
Post to the Community
New Post
Announcements
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
