I have the job processor set up now, but I have yet to get it to successfully publish a file. With every file, I get one of the following three errors:
1) Non unique Visualization file - I have yet to find a duplicate dwf when I get this error.
2) Login Failed - Does the job processor log out when it is idle? I did not get an error when entering the credentials in the job processor settings.
3) You do not have adequate permissions - Really? The admin account doesn't have adequate permissions?
I searched the entire vault for the file name (minus the extensions). Only the DWF and the DWG are found. Checking the file out and in with AutoCAD Electrical does not give the same error. Neither does the Update (locally) button inside Vault Collaboration.
I'm assuming the login fails because all of our Vault licenses are being used. If a file fails because of a login error, is there a way to get it to automatically retry?
No, I haven't found a pattern to the permission problem. What would the parent problem be with ACe files? The WDP file, or the other files in the project?
Are you using Enforce Unique File Names?
I would say that the login error would be the lack of a vault license. No there is no way to get it to automatically retry.
The parent file is the DWG file you are making the DWF file from.
Yes, we are enforcing unique file names.
Actually, regarless of the CAD application, I know the parent file was checked in. The task is sent to the job processor as I am checking the files in.
As far as the duplicate error message, what I believe it is happening is that it sees a duplicate file when it attempts to check-in and therefore it doesn't check-in the DWF file the Job Processor has created. Turn off the Enforcement, Run the Job Processor on a file that has shown this error than click the "Find Duplicates" button next to where you enable the enforcement. This should at least show some clue as to why it is getting this error.
When I disabled the unique file name option, the job processor successfully created the file. However, the file name does not appear in the list generated by the 'find duplicates' button.
There is a large number of duplicates that already exist in our vault. They were created before we decided to set Vault to enforce unique file names. They are Content Center parts for the most part. We deal with them as they cause problems.
A search of the root folder for the file name has always found the files in the past. It does not in this case.
If I follow the following steps with a file that has this problem, the job processor will re-publish the file.
1) Disable unique file name enforcement.
2) Click the update button.
3) Enable unique file name enforcement.
4) Re-submit the file in the job queue
If there was a duplicate file somewhere in the vault, I should get the non unique file error again. I don't.
