We have job processor running.
Issue is if a file is checked in using the job processor to create the dwf, we need to select pause then resume within the job processor for it to process.
Is this a known issue or is something set up incorrectly?
Solved by gandhey. Go to Solution.
Can you try modifying the following parameter in "InstallDir For vault Pro"\Explorer\JobProcessor.exe.config file. ?
<add key="PeriodInMinutes" value="10"/>
Default is 10, you can alter this period. And the Job Processor is started accordingly.
Hope this helps.
Yogeshwar Gandhe
Autodesk - Vault QA team
