I would like to create an item report (based on Item Detail.rdlc). I would like to display the associated files and some 1st level BOM information…
Does anybody, have tried some code in order to achieve this kind of task?
Thx
Regards
Xavier
Hi
Please go through the following document which helps you to create your own Report Template.
http://images.autodesk.com/adsk/files/report_template_authoring.pdf
Hope this helps you.
This document does not really help me for what I try to do…
I run a report which return an item list and display the detail of those item properties. What I would like to do in this report is to display information coming from the different documents attached to each items of the report…
I know this could appear to be a strange… but it is exactly what we need to do… ;o|
Xavier
