Vault General Discussion
Employee
8 Kudos
Post 11 of 14
Re: Item Number Based on Filename
10-05-2010 05:51 AM in reply to: pderby3
Yes, it is possible.
You need to add an additional Initial Mapping to Component Name property.
See my attached screenshot.
Scott Mollon
Quality Assurance
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
Active Member
0 Kudos
Post 12 of 14
10-05-2010 10:16 AM in reply to: mollons
Scott
Thanks for the advice.Filename is now mapping to the item number.
0 Kudos
Post 13 of 14
05-08-2012 05:49 AM in reply to: pderby3
Can you do this with a TIF file? I'm using VP 2012. I created a property called Component Name but can't seem to map to it. I would like to take a whole lot of legacy TIF files from an old system and put them in the Vault. If I could map the filename to Item that would be great - Or even if I add a custom vault property to the tif file and then map that to the Item.
Thanks in advance for any advice.
Employee
8 Kudos
Post 14 of 14
05-10-2012 08:13 AM in reply to: chris.turner
You should be able to map to the filename of the file and use it as the item number.
Other properties on a TIF file I am not sure about.
Scott Mollon
Quality Assurance
Autodesk, Inc.
Post to the Community
New Post
Announcements
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
