Vault General Discussion
Active Member
justin.erp
Message 1 of 5 (179 Views)
Issue with .dwf creation on file check-in with Vault 2009
179 Views, 4 Replies
03-04-2014 08:07 AM
I'm having issues with creating .dwf files when I check in files to Vault 2009.  As far as I can tell, I have all of the correct settings checked in order for these files to be created.
Thanks for the help!
mthomas
Message 2 of 5 (137 Views)
Re: Issue with .dwf creation on file check-in with Vault 2009
03-10-2014 06:12 AM in reply to: justin.erp
Can you create DWF files manually from the CAD application? This is usually the first thing to check with DWF issues.
Is TrueView installed? and if so can you generate DWF from your CAD files using it?
Mike
Mike Thomas
Active Member
justin.erp
Message 3 of 5 (116 Views)
03-12-2014 12:02 PM in reply to: mthomas
I am able to create .DWF files by completing a "Save As" while in Inventor & True View is also installed.
mthomas
Message 4 of 5 (104 Views)
03-13-2014 07:31 AM in reply to: justin.erp
What happens if you click the Update button looking at a file within the Vault Client?
Mike
Mike Thomas
Active Member
justin.erp
Message 5 of 5 (95 Views)
03-13-2014 11:46 AM in reply to: mthomas
So I started with a fresh install of both Inventor & the Vault on a different PC.  With the new installtion I am now able to create .DWF files when I'm checking files into the Vault.  My next step is to duplicate the fresh install process on my PC since there must be some setting that is causing it to not create the files.
Thank you for taking the time to try to help out, I appreciate it!
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
