I inadvertently assigned a user defined property called “Drawing Type” to an ipt file.
I am unable to delete the property value, even though it should only be enforced with idw or dwg file catagory.
This user defined property is set to only be enforced with idw or dwg files yet, after adding a value to an ipt model catagory I am unable to remove the property value without it leaving a Non-compliance flag . See attached for a series of screen shots describing the issue.
My hope is to find a way to clear this value without leaving the resulting Non-compliant policy warning symbol.
Solved by Neil_Cross. Go to Solution.
I dunno if you've cleared this up already.
I totally see the problem, once you've assigned the property to that file it's practically impossibe to clear it off and remove the non-compliance if you leave the property value as blank.
The problem is due to the property requiring a value globally. In your property (Tools > Administration > Vault Settings > Behaviours > Properties), edit it, on the left hand side you'll see 'Property Values' and on the right hand side you'll see 'Category Values'.
Change the 'Requires Value' to FALSE for Property Values, but then change it to TRUE in the Category Values. Following this, it'll only flag for non-compliances on the categories assigned to the property.
Warning though, doing the above will execute and kick off a global Vault property compliance check which canes the Vault for a good couple of hours depending on size whilst it verifies all properties. That's what happens when you see the little stopwatch symbol against all the files. So if you're in a busy office, do this at the end of the day when people are going home.
Once you've changed the above setting, check the IPT out then back in. This will immediately clear the non-compliance on that individual file.
