Hi all,
I'm thinking about the migration of Inventor files from 2012 to 2013 for a Vault Workgroup Customer.
This customer met problem in the past with none migrated data and he want to migrate all Inventor data to 2013.
But he uses LifeCycle. Then with the Inventor Task Scheduler we will met this behavior:
2012:
Assembly.iam (Rev A) use Part.ipt (Rev A).
Part.ipt has a Rev (B)
2013:
Execute a task migration with a user who has write right on Release files.
Now, Assembly.iam (Rev A) use Part.ipt (Rev B)...
It's very dangerous! You will loose almost all consistency btw revision.
Does Inventor can work without any problem with Vault Workgroup if there are none migrated files (Edited out of turn by example). Is there some option to make this work?
Thanks in advance.
