Lately I have noticed that when I open an Inventor assembly or drawing file that is checked in to the Vault, the top level of the assembly and sometimes some subs, will spontaneously check out and will have the asterisk next to them in the Inventor Vault tab.
Did I set something somewhere? I'd rather be prompted as to wether I want to check out... because I prefer to use Get Revision.
Vault Pro 2013
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
@HUSELALU wrote:
Check your prompts settings under Tools>Options>Configure Prompts
All prompts set to "Always Prompt".
Chris Benner
Chris,
Have you tried checking in the entire assembly, relinquishing ownership of everything, deleteing the entire assembly and its contents off of your local and then checking out just the assembly?
Just wonder if this falls under the category of odd and rare occurances that the system just needs a kick in the pants.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Oh, it needs a kick all right.....
This seems to happen if I open from local or from Vault. What I have not tried is checking everything in and deleting local, THEN opening from Vault.
Chris Benner
Easy now!!!!
Let me know how this works out for you.
Sorry, Vault gets my BP up some days.
Chris Benner
No problem. I'm here for you.
I know Inventor and vault both get me going at times myself.
Hi, I'm having the same issue (after installing autodesk vault basic 2021.) I changed the prompt to ask, and when I open .iam from vault it askes me if I want to check the asm out, I clicked 'no', and the file opens...CHECKED OUT, as well as a seemingly random set of sub components. Any ideas please?
