Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Invalid Property revisited
2 REPLIES 2
178 Views, 2 Replies
OK, I've had this situation before and can't remember how I fixed it.
When trying to perform Property Tuning, there is a property at the top of the list which is blank, no name not used by any file, set
to In Use, but you now cannot do anything in the Property Tuning other than click the Cancel button.
How do you go about fixing this?
BTW, running on full SQL, so is it a case of manually deleting that entry from one of the tables, or running a maintenance schedule
to compact and repair the databases?
TIA
John Bilton
2 REPLIES 2
What has happened is that there's a row in the PropertyDef table with a
blank "FriendlyName" column. That needs to be deleted. Don't attempt this
unless you know what you're doing!
- Jeff
"John Bilton" wrote in message
news:5128214@discussion.autodesk.com...
TIA
John Bilton
Thanks Jeff - will wait till I get back from Salzburg!
John Bilton
"It seemed like a good idea at the time..."
