I am attempting to load several leagacy files into the vault. When I first attempted to upload the files I recieved a message that "the project file includes the folder whose name is not valid". Ha, I thought "I will work around this" So I did a Pack-and_go on all the drawings and assemblies to move the files all into a single folder. However, when I now attempt to run the Auto Uploader I still recieve the same message. I have attached it here. Can someone please give me some guidance as to what will help me past this problem?
Thank you
Solved by Senthil_Kumar. Go to Solution.
Hi Jim,
I see that some folders are named as .25 Plate and .375 Plate. Is that true? If this is the case can you please change them to 0.25 Plate and 0.375 Plate and then try Autoloader?
In Vault you cannot create a folder with a name starts with DOT.
Let me know if you need any further help/info.
thank you. I will give that a try. I suspected it was something simple I was over looking.
