Ok, thanks for trying that Jorg..
Can you download regmon from www.sysinternals.com? Run this on your machine,
then try doing a change/repair of your Autodesk Vault 5 client.
Alternatively, with regmon running, you could also try the manual
registration of the InventorVault.dll again.
The intent of this troubleshooting exercise is to capture the regmon log
while you reproduce the problem. If there are registry permissions as Jeff
is asserting, then we should capture those in the regmon log.
After this error pops up when you do either a change/repair or the manual
registering of the DLL, search the regmon log for "denied". You could even
try both.. let both produce the error.. then you will likely have two
occurrences of the "denied" error in the log.
You can use the log entry to determine where there's a permissions problem
in the registry, if that is indeed where the problem is. If nothing is
captured, well.. you probably don't have a registry problem, but something
else is going on.
Hope that helps,
Bob
wrote in message news:5142114@discussion.autodesk.com...
no beta installed only the brand new shipped version.
while installing the dll manually the new error message is :
Dllregisterserver in inventorvault.dll failed. Return code was: 0x80070005.
ok, and what's next??
