Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Installing VAULT 2015 Win8 64
4 REPLIES 4
FedotovAnton
389 Views, 4 Replies
I have a problem when installing Vault 2015 client on Win 8 x64. So, it's ok on the server side, client installed normally and works.
An error like this:
"The procedure entry point ?SetRetryButton.. could not be located in the dynamic link library m~/SetupUi.dll", see the attached screenshot (russian language).
Any ideas?
Thanks, in advance.
Tags (3)
4 REPLIES 4
Hi Anton,
The error seems to be pointing at a situation where the DLL is in corrupt state or not properly downloaded. May I request you to :
1) Either :- Copy "SetupUi.dll" from the "Setup" folder in server installer media; and paste it into the "Setup" folder in Client installer media. Now, run the installation again.
2) Or :- Download the Client installer again and then try to install.
Please do let us know if the error is resolved.
Saurabh
Hi Saurabh,
I've already tried to do this. There are no results. Also I've tried start the installer from a shared folder. All the same.
It seems a problem directly on my PC, but I don't know where look for it.
Anton
Hi Anton,
Thanks for sharing the results.
Wanted to get more information, so that I can try to reproduce at my end. What are the steps you took before you see this error message ? Can you please let me know, at which step this error is seen ?
Also, does it help if you clean your %temp% directory and start the installation ?
Saurabh
I took no steps before the problem appears. I suppose, it's Vault 14, installed on my PC. I deleted it and all of the components regarding to it, but it didn't help. Yes, I cleaned my TEMP - no results.
Anton
Tags (3)
