I'm trying to install Vault 2015 Basic on SQL 2012 server. The problem I have is that the Installation is not recognizing the SQL server. If I create an AUTODESKVAULT instance, the installation requests to be removed because it is an unused database. I cannot add the sa account because it is already there (we have other databases installed). The installation goes through but installs the SQL 2008. How we can install Vault on the existing Database Engine?
Thanks.
did you follow the advanced config guide?
http://download.autodesk.com/us/vault/2014/2014_Advanced_Config_Guide-2014.pdf
DarrenP
Is there a written procedure on how to upgrade the Vault database to SQL 2012 and install the software? Thanks.
Hi Herb,
Please find the steps to install and upgrade SQL in the Advanced Configuration Guide.
Windows Server 2012
SQL Standard 2012
Vault Basic Edition 2015
Following the advance configuration guide
The Error while trying to add the Vault database to SQL 2012: "the AUTODESKVAULT instance is not in use". The only way to continue is to delete the instance then installs the SQL 2008 espress, which is not what we want.
