I'm running into trouble with an upgrade installation. Vault Basic 2012 on a windows 2003 server standard, IIS 6 is running with no issues. I'm running through the upgrade to Vault 2013 and getting stuck in the System readiness tests. the log states that there is a problem "Accessing an http static file failed at URL http://localhost:80/TestASP/TestASPNetStatic.txt" and the bottom of the report gives "The remote server returned an error: (404) Not Found". When looking at the suggestion to fix this specific error the one listed is that permission isn't given for the default internet user, but that doesn't seem to be my issue, the permissions to the wwwroot folder are ok per the vault installation help instructions. I'll post the full output of the readiness check here, and thanks in advance for any help you can provide.
Autodesk Diagnostic Tool Log File Checks
Verifying that a reboot is not pending. | Successful | |
Checking Operating System | Caption=Microsoft(R) Windows(R) Server 2003, Standard Edition CSDVersion=Service Pack 2 OSLanguage=1033 OSProductSuite=272 OSType=18 ProductType=3 ServicePackMajorVersion=2 ServicePackMinorVersion=0 SuiteMask=272 Version=5.2.3790 | Successful |
Checking for a Proxy Server | Successful | |
Validating Performance Counters | Successful | |
Checking port 80 for availability | Does not apply. | |
Validating that IIS Anonymous User Account is set up correctly | Anonymous user "IUSR_DELL2" found. | Successful |
Validating that IIS Anonymous Authentication on IIS is set up correctly | Successful | |
Validating IIS .Net settings | Successful | |
Checking for additional IIS ISAPI filters | Successful | |
Checking IIS directory paths | IIS website Default Web Site root directory = c:\inetpub\wwwroot | Successful |
Determining IIS website Default Web Site Internet address(es). | IIS website Default Web Site server bindings = :80: | Successful |
"AutodeskDM" virtual directory existence check | Does not apply. | |
Check IIS connection time out. | The IIS connection time out is :900. | Successful |
Checking ASP Status | Accessing an http static file failed at URL http://localhost:80/TestASP/TestASPNetStatic.txt. | Failure |
Check permissions of the account used by ASP.NET. | Successful | |
Checking SQL version of Vault database instance. | Vault database instance SQL Version = 10.0.5500 | Successful |
Checking SQL Server '.\AUTODESKVAULT' | The database instance ".\AUTODESKVAULT" was found.Database server ".\AUTODESKVAULT" is running.Connected to SQL Server '.\AUTODESKVAULT'.Successfully connected to database 'KnowledgeVaultMaster'. | Successful |
Checking site compatibility with the database | The database instance ".\AUTODESKVAULT" was found. Product to be installed: 'Autodesk.Vault' This server (DELL2) is already registered in the ADMS master database | Successful |
Checking for existing Vaults with a remote FileStore | The following existing Vaults were found - Vault : D:\Documents and Settings\All Users\Application Data\Autodesk\VaultServer\FileStore\Vault\Vault | Does not apply. |
Validating that this host name can be resolved on the local network | Server hostname as known by DNS = dell2. Server is resolved to following IP Addresses by the DNS: 10.0.12.250 | Successful |
Checking for known firewall | Does not apply. | |
Check administrative account creation. | Successful | |
Checking for a compatible Security Policy | Does not apply. |
Exceptions
Exception | The remote server returned an error: (404) Not Found. |
i think this has to do with IIS not using .net 4
DarrenP
