This has happened a few times now:
None of the panels have icons on them, so it's unusable.
Now everything will work again.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Hi Scott,
Just tried this and I am not seeing the issue. I used PrDS. Please let me know if you happen to see again.
I'm using FDSU. I haven't installed PrDS in this way yet. So maybe it's something odd about FDS?
Scott Moyse
Ah....Let me try with FDSU then. Will update you.
Scott,
Tried with FDSu as well and I am not seeing it either. Vault add-in is loaded.
Hi Senthil,
I've been thinking about this a bit more and I've realised I've put you crook, Sorry! The steps were wrong, I realized I missed out some fairly decent steps. Here are the steps I believe are causing the issue:
The Revit/Plant 3D stuff could be messing with it?
Scott Moyse
Hi Scott,
Tried that as well. But i have few questions.
