I am in the middle of going from Vault Basic 2012 to Vault Pro 2015.
I wanted to get to Vault Basic 2014 and then pull my clients up before moving on. Then stop there until after AU to help me get a clear view before going to Vault Pro 2014 then to Vault Pro 2015. However, management would like me to get us to Vault 2014 Pro before AU even though I am saying I will not have time to develop the pro use by then (lifecycles, approvals, etc).
So in ordered for me to consider this I have a few questions that I need answer. I have asked these within other threads recently but I do not see a clear answer yet.
1) Can an installation of Vault Pro be used by the clients just like the versioning style of Vault Basic until I define the workflows? Basically everything from a users points stays as Work in Progress. I just do not want the users to have something to deal with that I have not worked through and setup yet.
2) If they can use a Pro install just like a Basic install, is there a way in the ADMS console that I can prevent them from changing states by accident before I have time to develop my methods?
3) I understand that a Vault Pro ADMS 2015 install can run a 2014 client basic but does that mean that the 2014 client base will need a 2015 add-in to communicate? I assume that Vault Explorer would have to be 2015 but the question is about all the clients add-ins (IV, Acad, Office).
Just assign users to the 'Document Editor' permission roles, don't associate any 'Document Manager' roles.
Then they can't utilize or change the workflow states, until you get everything setup.
So basically that answers questions 1 & 2. They can use it just like a versioning Vault AND I can prevent them from the ability to do anything beyond that until I am ready.
So that works for if I am on 2014 PRO with a 2014 client base.
Anybody got an answer for question 3? Would really like Pro 2015 on before I go to AU but need to be sure it is stable while I am gone also.
"If you aren't going to have the lifecycle states and workflows set up, do your best to keep thing in the base category and without a lifecycle definition."
My intention is to upgrade to Vault Basic 2014 and then upgrade my client base to 2014. Then upgrade the server to 2014 pro (then maybe even to 2015 Pro) before I go to AU. However, I will not do anything with lifecycles or the existing categories of the files. At this point ALL of my users are just Document Editor 2 level on Vault basic 2012. Those setting will come across from the restore. I would assume that if no user has the ability to change a file state and/or assign a workflow then it would just act as the existing 2012 Basic vault does now. Check In, Check Out, Versioning.
Still anybody got anything on question #3?????
Vault Basic will not be able to log into a Vault Pro server.
However, Vault Pro 2014 CLIENT can log into a Vault Pro 2015 SERVER.
#3. Vault add in needs to match the version you are running
if your running 2014 products you still need the vault 2014 add in to communicate with the 2015 vault
2015 requires the vault 2015 add in
with the office products with the 2015 vault in you get the outlook add in
DarrenP
Agreed, the ADD-IN version must match the APPLICATION Version.
Example:
AutoCAD 2014 must have the Vault 2014 Client installed for the add-in.
OK so let me make sure I am straight here.
It seems you are both saying the same thing.
I can upgrade the server to Vault Pro 2015 and communicate with it using the 2014 products (Pro Versions).
My intended path is:
Backup Vault Basic 2012 (Old Server)
Restore to Vault Basic 2014 (New Server)
Upgrade Vault Basic 2014 to Vault Pro 2014
Upgrade client base to 2014 (with 2014 Pro Explorer and Add-ins)
Upgrade Vault Pro 2014 to Vault Pro 2015
So now I have a client base that is running all 2014 products communicating with a server running 2015 Pro.
All users will stay as just Document Editors and no Lifecyles will be used until I define it as I see fit.
OK I have one more point I need to be clear about:
