In Vault Collaboration 2012, is there a field column which can be added for grid display, or a search criteria which will display if files require migration.
I know you can r-click on a file in win explorer, r-click, pick iproperties, and on the details tab, you can see if migrate is required.
Also, I know about customizing 'Design Assistant' to verify if files require migrating.
I wondered if this could be done directly within Vault as a field column, or as a search criteria?
I've been unable to find a way to do it, and Google searching isn't turning up results.
Solved by cbenner. Go to Solution.
This sounds like a job for a User Defined Property. You can create a property in Vault that you can map to the property in Inventor, with the mapping direction going from File to Vault. Then when you check in a file from Inventor, that property should reflect the state of that property in Inventor. Once it's there you can use it as a search property or add it to your project explorer screen and sort by it.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
If you need help with it, let me know.
Chris Benner
Hi
I thought I would try to map the properties in Vault, but when selecting an Inventor part, the Details tab properties do NOT appear.
Has anyone else found the properties from the Details tab?
Regards
Max Bodnar
I don't have 2013, I use 2013 and we don't have a "Details" tab... but I do have a "Physical" tab that contains physical properties of the part... and I don't see those as mappable. Same thing perhaps?
OKAY, I see what you are looking at now, this is from Windows Explorer... my bad. But, no I do not see any of those properties in the mapping fields.
Chris Benner
Hi
Sorry for the late reply, yes Details tab is only available through windows explorer
I thought the original post indicated that there might be a possibility to map these properties in Vault so they can be visible. That would be very useful
But since these are not visible when trying to map, I cannot see how they can be made visible in Vault
Unless I am missing something
Regards
Max Bodnar
